Wireless Access to the PLC
asterof
May 2007
Califonia
554
So I have a Ethernet loop located in a tower
about 350 feet above ground
I do not care to climb up to program the system
so I want to install a wireless connection into the remote
IO loop,(see drawing)
I have included a drawing and am asking for what
adapters I need to do this, because of all of the
wireless adapter types, it get confusing
Since the ethernet network is isolated to the tower and doesn't need a connection to the plant network below:
Easiest thing to do would be to put a wireless Router or Wireless Access point up in the tower and create "Tower Wireless" network up there. Much like your home router your can connect to "Tower Net" over laptop wifi. You will need a router/AP and good antenna to give you the 350'+ range.
See if you can drop a CAT5 cable down one of the conduits leading to the ground. Most reliable solution.
They way you have it drawn would require a wireless bridge which requires 2 units but is a relatively secure system. If you put a wireless access point on the tower it would allow multiple PC's to access the system through the access point. There are also some devices out there that do both.
Not if you want it to last. Whatever you put outdoors needs to be rated for outdoor use.
That device is meant for offices and living rooms.
Putting it in an enclosure will reduce the range/signal.
Do you plan on putting the Wireless device you buy in an enclosure or out in the open?
With external antennas a Access Point/Router can be happy in an enclosure.
http://www.moxa.com/Event/IW/2013/Industrial-grade/Index.html
Call these guys, ask for an applications engineer/support and tell them what you want.
They will give you options and good advice.
Not a pro, but.. Keep in mind you need devices that tackle that distance on both ends. If you have a wide area AP on your PLC side, but try to connect to it with your built in WiFi, you will be able to see/receive the signal, but will be unlikely to be able to transmit any information to it.
+1 for running a cable down the tower.
Replace the 6 port ethernet switch in your diagram with a 6 port + Fibre, and run a fibre optic cable down to a similar 6port + fibre switch at the base of the tower. 350 ft is about 20 ft too long for a CAT 5, 6 or 7 solution.
If I wanted reliable wireless at that range, I would pay for a wireless network specialist to do some sort of on site radio survey, preferably one with industrial automation knowledge.
+1 for the ubiquiti. I've set up a couple of them before and they were very quick and painless. Obviously running a cable down would be more reliable, but if that's not practical then a ubiquiti point-to-point unit should work nicely.
You could probably talk your local ubiquiti distributor into bringing a couple of units out to test over the distance, make sure you get a suitable one before you spend the money.
Almost any WIFI router can perform in AP or Bridge mode among other modes.
Ubiquiti would be a good choice but a standard Ubiquiti AP and a directional antenna would work fine. You don't really need a dedicated point to point setup for this.
As far as security point to point bridge is no more secure than AP mode and can be less secure depending on the device.
Get something outdoor rated and give Ubiquiti a call and they can help you select the best antenna from their offerings.
Another option could be to use 2 Anybus Bluetooth Wireless bridges. Once they are paired, they will only communicate with eachother. In a noisy enviroment, they are very robust as they use 8 frequencies at all times and will use frequency hopping in case of disturbance...
They are IP65 and the range is up to 300meters.
http://www.anybus.com/support/support.asp?PID=486&ProductType=Anybus Wireless Bridge
My 2 cents
Patrick L
I spoke with Ubiquiti Networks and they told me to use two of there
NanoStation locoM5 units.
locoM5
Frequency 5 GHz
Throughput 150+ Mbps
Range 10+ km
and set them up in POE bridge mode
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,037
I try to connect to a PLC via 4G usb wireless adapter. My setup is a PLC, HMI, Craddlepoint routerMBR95 and a T-Mobile Rocket USB adapter. I...
3,482
I want to communicate with a dlink pocket router / access point to an allen bradley 1756-L61 ControlLogix 5561 controller through an ethernet card...
19
10,810
Hello all, This is my first post, so i hope im doing it wright. Let me start by saying im not a PLC pro, i started to learn programing on my own...
3,861
Does anyone have a recommendation for a wireless access point that they like? I am putting them on a controls network with no DHCP. Everything is...
2,727
