Wiring PWM ouput to Stepper drive -s7-200
michaelruban
Nov 2007
MUMBAI
Hello,
I am using s7-200 siemens plc cpu-224. I would like to run my stepper motor through the pwm output from the plc. How to connect my drive to plc?(wiring diagram)
Is any body have the sample program with explanations for pwm as well as pto for the same.
Advance thanks!(y)
Ruban
Dear Brock,
Thank you for your reply! I have downloaded the files and studied. I have connected accordingly, but the motor still not working?
I am using a Ezstepper drive for my stepper motor with pulse amd direction mode. Should I need 600 ohms load resister on that as shown in the example.
Please help me.
Ruban
Sorry, but I didn't use the PWM output for stepper motor control, so I don't know. I think you need first to find, if your software works correctly (LED of Q0.0 must lit - maybe with lower intensity - depend of Cycle time/Pulse Width ratio. For this test it is better to disconnect the wire from Q0.0) If so, the mistake is in connection, if not the mistake is in your software. In my application the resister is not necessary, but in your application with Ezstepper drive it shouldn't be like that. I am not able to tell you more.
Posted this to Reddit with little success, so I figured I would share it here as well. Very new to PLCs, but figured I would give it a shot to...
125
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
82
Hey guys, the scenario is: I have already completed the drawing package for my system utilizing an A-B 440R-N23126 (Minotaur) safety relay. SoS...
146
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
114
Hello I wanted to ask some questions about the G120C drive and the protection for it. I want to control a pump, with the motor rating of 5.5 kW...
200
