wonder ware
RY_Guthrie
Nov 2011
Las vegas, NV
263
I am trying to run wonder ware archestra, I have in touch 10.3 sp3. the problem is when I try and start archestra I get the message that archestra has stopped working and window is looking for a solution and then the window closes. I am running windows 7. Has any one seen this same problem and more importantly does anybody have a fix? Thank you
archestra
109678 10/31/2012 5:59:21 PM 11728 12216 Info wm Wonderware SSC - Version 7,0,100,1 (3 : 1.1) (2 : 4.1) (3 : 5.0.97)
109679 10/31/2012 5:59:21 PM 11728 12216 Info wm Unable to start NetDDE
109680 10/31/2012 5:59:21 PM 11728 12216 Info 16PENTREND Invensys Systems,Inc. InTouch 16-Pen Trend Wizard 10.1.300 NT
109681 10/31/2012 5:59:21 PM 11728 12216 Info WC Invensys Systems,Inc. InTouch Windows Controls 10.1.300
109682 10/31/2012 5:59:21 PM 11728 12216 Info WC WC shutting down...
109683 10/31/2012 5:59:21 PM 11728 12216 Info WC Invensys Systems,Inc. InTouch Windows Controls 10.1.300
109684 10/31/2012 5:59:21 PM 11728 12216 Info WC WC shutting down...
109685 10/31/2012 5:59:21 PM 11728 12216 Info WC Invensys Systems,Inc. InTouch Windows Controls 10.1.300
109686 10/31/2012 5:59:22 PM 11728 12216 Info WC WC shutting down...
109687 10/31/2012 5:59:22 PM 11728 12216 Info WC Invensys Systems,Inc. InTouch Windows Controls 10.1.300
109688 10/31/2012 5:59:22 PM 11728 12216 Info SQLMNGR 10.1
109689 10/31/2012 5:59:22 PM 11728 12216 Info INTSPT DBFileValidation check is set to 0
109690 10/31/2012 5:59:26 PM 11728 12216 Info SPCDLL Wonderware SSC - Version 7,0,100,1 (3 : 1.1) (2 : 4.1) (3 : 5.0.97)
109691 10/31/2012 5:59:26 PM 11728 12216 Info SPCDLL Logger Subsystem
109692 10/31/2012 5:59:26 PM 11728 12216 Info SPCDLL Creating Dispatch Interface to Server
109693 10/31/2012 5:59:26 PM 7436 11072 Info SPCPRO ERROR: --------------- Database Error Information ---------------
109694 10/31/2012 5:59:26 PM 7436 11072 Info SPCPRO ERROR: Server () Database () ODBC Data Source (SDFGSDAF)
109695 10/31/2012 5:59:26 PM 7436 11072 Info SPCPRO ERROR: ODBC ( Data source name not found and no default driver specified )
109696 10/31/2012 5:59:26 PM 7436 11072 Info SPCPRO ERROR: ODBC ( State:IM002,Native:0,Origin:[Microsoft][ODBC Driver Manager] )
109697 10/31/2012 5:59:26 PM 7436 11072 Info SPCPRO ERROR: Unrecognized ODBC RETCODE = -1
109698 10/31/2012 5:59:26 PM 11728 12216 Info SPCDLL Successfully Created Dispatch Interface to Server
109699 10/31/2012 6:01:13 PM 11728 12216 Info INTSPT No license for InTrack development
109700 10/31/2012 6:04:30 PM 7552 11684 Info AlarmMgr AlarmMgr on SIRIUSTECH-003 shutdown
109701 10/31/2012 6:04:32 PM 11728 12216 Info WC WC shutting down...here is the smc log or at least the last few entries
Well ,
Have you followed the proper installation steps?
If you go to the Wonderware Developers website you will find a technote on the installation .
Maybe have a look at your application error logs as well.
Also explain your architecture what platforms ect. The more information the better.
IM running windows 7 64 bit os, I have sql installed on my laptop, what is the developers web sights address? I installed the software, intouch, and then realized I didn't have the archestra lic so I loaded it last. thanks for the help.
I will have to re-install the software, Im assuming and I will start over from there. thanks
Go to
www.wonderware.com
Under support tab you will see login in to Wonderware Developers Network.
Be sure to see if the SQL installed on your laptop is supported. The installation as well as the SQL should be provided with the Disk set from Wonderware. This disk set also has all the required documentation for the installation process.
Make sure you follow the installation guide for SQL.
Also look at the OS requirements.
Hope this helps
Rheinhardt
Hello again. For years we have been using WonderWare for our HMI interfaces. Starting about a year ago we started experiencing the sticky button...
2,593
Hi Guys, How can I run full screen on wonder ware Intouch window viewer?
5,879
I have a wonder ware application running on several computers, they are all the same app, stand alone. No galaxy. Under system management...
1,626
I was wondering if there is any other documentation, examples or other help out there on wonder ware scripting, quick scripts besides the in touch...
1,504
I am trying to find a easy way to edit the tags in a smart symbol, is there a way to copy and past, or use a csv file to just change one smart...
1,423
