Wonderware Historical Trend
Nan
Jul 2015
louisville
126
I am new to wonderware, I am having a question that is it possible that wonderware Historical trend can provide six month trend? I am having 13 tags need to be stored and provide up to six month trend. If this is possible, how can I set it up, where are all the tag data need to be stored.
Thanks,
The Historical trend in Wonderware will only allow 8 pens (tags) to be trended at 1 time.
Yes it will support 6 months in the trend window....but that will be a lot data crammed into the trend. What resolution is the application?
There is a 16 pen application for Wonderware also.
It depends on the type of Historian you have. The Standard and Enterprise historians will store trends for well over a year if you have the data base memory.
Local Historians store data for 7 days.
Are we talking classic Intouch logging or InSQL historian? I'm picking you mean classic Intouch logging which is what NetNathan is talking about
6 months of trend data will take a while to display depending on the logging configuration of the tags. But you can store log files indefinitely, the only limit is disk space. As NetNathan says there's a 16 pen trend but i have never had need for it. Even 8 pens on a single trend can make it difficult to see what's going on depending on the process.
Hello, I am working on a SCADA system using Wonderware Intouch 2014 R2 and have a small glitch with the historical trend feature. Every time I...
2,877
Hello folks, Under our current bleach plant wonderware HMI program there's a bunch of historical trends as well as real time trends. What I need...
14,273
I'm not used to Wonderware, and I can't seem to see where I can setup how often tag(s) are logged. For testing, I have two analog tags setup to...
9,428
I am using Historical Trends please refer the attached image. I described the slider as s1, s2, s3, s4. I need to view only the selected pen in...
1,251
Hi, I just ran into an issue where the InTouch historical trending is not functioning properly, and when I look in task manager, the historical...
3,711
