Wonderware Modbus TCP/IP troubleshooting
PLBoudette
Jan 2006
Albany, NY
41
I am doing a modification on a wonderware application using modbus TCP/IP. I previously worked on a wonderware application with modbus TCP/IP awhile ago. The old application was using version 8.0.1 0511.0166.0000.0000. In that version, I created an access name and used the application name “MBENET” and a topic name. Then I went into the “MBENET.EXE” program, created a new topic and set everything up as needed. The new application I’m working with uses version 9.5.100 1101.0600.0150.0030. I went to try and setup the modbus but it seemed to be a different type of setup that was needed and didn’t see the MBENET.EXE program. Does the newer version have a different setup than the one I previously used? Or is the modbus TCP/IP driver a separate driver that I need to install? Any help on setting up the modbus TCP/IP for wonderware is appreciated. Thanks.
[FONT=&quot]Pete[/FONT]
I think you are calling off Intouch version numbers instead of the IO sever's. The older version of IO server for the Modbus Ethernet driver only go up to 8.1.0 and the new Device Integration MBTCP DAServer server is currently at version 1.5. If you are installing the latter, the configurations for the driver is integrated into the SMC (System Management Console).
Hello, I am attempting to add some IO Discrete tags to a AVEVA InTouch project (version 2020). These tags use the MBTCP driver and attempt to map...
1,211
So I am trying to access data from an Eaton PXG900 Power gateway with Wonderware. The gateway can be polled for data by Modscan and does provide...
2,873
Hi all, I'm currently doing a project which is using Fatek PLC and In Touch Wonderware as my SCADA monitoring. I'm facing problem on the...
11,083
I'm creating a new HMI to communicate with a Yaskawa controller. I started adding some of the values to the screen from the 4XXXXX registers and...
2,439
Hello I'm trying to read a register from a Modbus device into Wonderware System Platform. In object viewer it shows the status of being "Good"...
1,928
