Wonderware Script Issue
ControlLogix
Feb 2003
Southern Ireland
62
Hi guys,
It has been a while since I've posted here but wouldn't you know it, I am posting because I've reached the end of my thether after troubleshooting a Wonderware condition script for the last two weeks (on and off, when time permits!).
Here is a part of the script which is failing on me:-
PP_EF_Start_Hr_String = StringFromIntg(PP_FE_Last_Start_Time_Hour,10);
All this script is doing is converting the PLC register value to a string value. I know the script is running since it logs the fact that is is activated to the WWLogger.
My problem lies in the fact that while the script activates, sometimes the script doesn't convert the value in the PLC to text even though both the PLC register and its corresponding tag have changed. There is even a timegap of 10 seconds built into the PLC between the time when the register changes in the PLC and when the condition script is run!
Nearly forgot:- There isn't any conditions within the script, the code is in the script as it appears above.
Has anybody got any ideas?
Regards,
Colm
If I understand correctly, sometimes the script works and sometimes it doesn't.
What integer values fail to convert? I assume that the '10' parameter in the function is the maximum number of digits? To me, that implies a 32-bit integer. Does the function work on 32-bit integers or could it be limited to 16-bit? Are the integers signed values while the script assumes unsigned (or vice versa)?
Colm,
What condition types are you using...On True/On False?
If you're not already doing it, 'try handshaking' the script call...
-Change the condition type to 'While True'
-Set the call bit/word value in the PLC
-Reset the call bit/word value at the end of the script
(Steve, the 10 is the number base representation required)
Kevin H
Hi all, Currently delving into Wonderware/Aveva System Platform for the first time, and I'm trying to set up a script to automatically write to...
940
I have an older application that seems to rely on ICTMOUSE.DLL. I cannot locate this script extension using good ole google ANYWHERE! Would anyone...
1,995
Hey I was needing help with some alarm scripting in Woderware System Platform. What would be the best way to write a script to auto acknowledge...
2,555
I have an intouch condition script that generates 8 different csv files everyday at 0830 and populates them with totals for the previous day. For...
2,433
Hi, I am trying to use Script function Library. I used Visual Studio to write the C# dll i will import in Archestra. So I import my dll...
2,592
