Work Around Proworx limit
commando
Sep 2006
DK
Hi guys
I am working on a modicon 984-141 plc, but my problem is that my modsoft don't work with my new pc. i have try to use it in a VMware with dos...but no luck, it looks like to work too fast.
I have downloaded the Proworx from Telemecanique and it works fine for me....but...and now the big question!!! is there anyone who know a work around for the limit of 25 networks??
I know that I can buy the software, but it is only for my private use to my heating system.
Thanks 🤞🏻
/commando
You get around the 25 network limit by buying a license. However Proworx32 is a piece of junk.
If you can get the modsoft software to run on doxbox you'll be way ahead.
I believe the 25 limit is the amount of "viewable" networks. You can insert as many networks as you want, you just won't be able to view or edit any one numbered greater than 25. You will however be able to print and delete them.
hahaha I agree. We are replacing all of our modicon 984 plcs with Beckhoff plcs for this exact reason
Referencing KB document QA9877: "...FactoryTalk View SE Graphics supports single precision floating point values, and by default only provides...
1,806
This forum post I found seemed to reference the same issue, and if posts were still allowed on that thread, I might make an account there to post...
5,805
Good Morning , I need to use a shift register to keep track of good and bad parts . As a rough draft I'm using 300 bits. When the 1's and 0's...
1,786
Good Afternoon , I know this issue has been discussed on here before , but I'm just wondering if any trends have changed. The shortage of...
46
16,229
I've been hoping to stumble across the answer to the green highlight box around the numeric entry button in FTV ME. Can someone answer this? (See Pic)
2,923
