Working intergrated with 300 CPU and TP900 in Tia Portal
userxyz
May 2002
any
2,768
I cannot make a connection that is integrated in the TP900...
Could the reason because of using a 300 CPU in Tia Portal ???
In the devices and Networks view, select Connections on the left side, then make sure that HMI connections is selected in the dropdown. Then drag from the HMI to the PLC.
Hello
Hello,
It is the case:
But still I cannot make an integrated connection.
Kind regards,
C
Ow
Ow,
After selecting HMI Connections I still had to draw the connection, understood.
Thanks guys,
Regards,
C
I feel like this is probably a very simple thing I am overlooking. (Compact Logix Studio 5000) This is my first time using the predefined...
257
I am creating a project with WinCC Unified v16 Upd6 (PC runtime) with an S7-1200. The communication is good between the PC and the PLC as I can...
242
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
393
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
94
Has anyone ever seen where you have a tag reading from the plc in scada. In this instance it's just a PEC, I set it up on one scada terminal and...
115
