Writing and moving multiple words
sahern
Feb 2005
Attempting to write 1600 word addresses for testing purposes. Any ideas,suggestions for the simplest way?
Am improperly asked question will always receive an answer that is not desired.
It may take awhile to write 1600 word addresses. What is a WORDS address?
WORD 1
WORD 2
WORD 3
This will take forever.
source??? > target???
The method depends on the media.
What is your source?
What is the means of communication?
What is the target?
No mention of type of CPU etc..here. Or data from what to what??
Take a look at your instruction set and look for the MOV or MOVE instruction. You should be able to move a block of words to another block in one fell swoop.
If you provide more detal you might get a better answer...
Use XFER (Omron) transfer function. Difficult if your PLC does not have the function but we do not which PLC you are using.
just some FYI, cause writing message instructions can be a pain, my company just purchased this product called a cATM...
2,207
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
279
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
106
Hello All: I have a Windows 10 PC running a FTView ME Station 10.00. I have a .mer file version 6.00. It has been running well on it for a long...
178
My R55 Ingersollrand is tripping on motor overload and im falling to see the trip history it is writing Acquarring texts
138
