Writing numeric values in Vijeo Citect...
donnedved1960
Jan 2012
Kansas City
I'm learning Vijeo Citect and I'm having the hardest time simply trying to write a numeric value in the PLC from a graphics pages. Can anyone point me in the right direction?
Thanks in advance for the help.
:geek:
:geek:
Have you set up comms between Citect & the PLC?
What have you done so far?
Have a look at the screen shot below. For a value to be entered (its a temperature setpoint TT24 for the tank on the left), we have a text on the screen - then under the text properties there is a tab for Input - the command is then "TT24_SP=Agvalue1"
Have a look at the under help for Variable Data Input (also shown on screen shot below)
I'm writing an app (or trying to) that will talk to up to 128 Modbus TCP devices. We're trying to put together an app that will be sold as a bundle with a product our company produces. I'm hoping the app can be self-configuring since it could be sold to less-than-IT-savvy kinds of buyers.
So the functions I need are:
Query the network for any devices that are on a certain UDP port;
Either change the IP address of a single I/O Device, or Add/remove I/O Devices within CiCode;
Thoughts?
We haven't purchased Citect as yet so I can't call support...
Thoughts?
Have a look at ClearSCADA I remember when I did their training course they a "self-configuring" project that communicated to multiple Modbus devices (flow computers).
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
101
My project requires that a pop up map pass a number or display a numeric display . While also someone should be able to enter the map number...
1,928
Hi all, First time poster here... until a year ago my ladder logic exposure was at a GM assembly plant in the early 80's, all on D size paper...
4,771
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
262
Hello All: I have a Windows 10 PC running a FTView ME Station 10.00. I have a .mer file version 6.00. It has been running well on it for a long...
173
