writing time to 1756-L55
diat150
Mar 2006
Louisiana
1,476
Is there a way to update the time in a 1756-L55 using wonderware? Id like to update the time every night at say 3am in the L55. Right now I am using a GSV to get the wallclocktime and then sticking it into an array.
There is another way to do it. I use Logix5000 clock update tool. This utility runs on my computer and I updates my plcs time (more than 60) every day at midnight. My PC is in sync with internet time so all my plcs have the right time.
thanks, I hadnt realized that tool existed. Ill keep it in mind if someone doesnt have a wonderware solution.
Even FactoryTalk View doesn't have a native clock update feature, so you probably won't find one in Wonderware.
The usual roll-your-own method is to use scripting or a macro function in the HMI to write the values of the year, month, day, hour, minute, and second into a set of registers in the controller, then trigger a Set System Variable (SSV) instruction to the WallClockTime object.
The SSV works exactly like the GSV you are already using, but in reverse.
Thanks Ken, that is what I was looking for. am I able to set individual values like hour minute second without touching the others like day, month, year, etc?
Sorry, I would try it, but I dont have a processor on hand.
Good question !
The sub-elements of the WallClockTime object are actually calculated from a single number in the Coordinated System Time object. They are not stored separately and cannot be set individually.
If you just need to change the Hour, you would use a GSV to grab the current WallClockTime, move a new value into the Hour sub-element, then write the whole array back to the WallClockTime object with an SSV.
Good question !
makes sense, thanks Ken.
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
319
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
133
Hello All: I have a Windows 10 PC running a FTView ME Station 10.00. I have a .mer file version 6.00. It has been running well on it for a long...
184
My R55 Ingersollrand is tripping on motor overload and im falling to see the trip history it is writing Acquarring texts
149
Hi. Not the fist time I'm saying this but just to give a background. 95% of my PLC programming has used Schneider over the last 10 years on...
66
5,203
