wrong time with GSV
backendcode
Aug 2017
brampton
249
Hello All,
I am working on program which other programmer wrote (Ladder logic) and the GSV time is wrong, I am getting 1998 year. How can I get the current time?
GSV classname is Wallclocktime and attribute is localdatetime.
I would appreciate if someone can help.
Thank you,
I think I found the issue. I went to controller properties and noticed the date/time is wrong there.
Quick question, Can I set/change that time to current time while online? because I can't stop the PLC or offline to change it because of the production line.
Thank you,
Yes, you can set it online. There's a button on that same tab "Set Date and Time from Workstation" or something similar. As long as your PC time is correct, just click that button and you're away. Or else you can manually enter the new date and time.
I am latching and unlatching "result_Data_latch" bit within same rung. Will This copy/move instruction execute correctly??
211
We have a quad monitor setup with FT SE and we are utilizing a header screen at the top of every display. when we open a new page we abort the...
117
Hi all, I am having an issue with FT View Studio ME when I try to open the propoerties of any object, the size of it is very big and doesn't let...
113
ewrong aka the censored brand of remote access this thing is kicking my butt and im not sure if i am just irritated enough that i am missing...
658
In Easy Builder Pro: Unexpected results... I've got a toggle switch set to trigger a macro to write a specified integer or a 0 depending on the...
2,345
