roxusa Lifetime Supporting Member R Join Date Nov 2008 Location NJ Posts 994 Oct 18, 2022 #1 On a Siemens drive to the encoder looks like a shielded Ethernet cable with only 4 pins used. Can I make this up with cat 6 cable and only use the 4 wires. OEM cant get the cable.
JRW Member Join Date Jun 2002 Location South Carolina Posts 2,304 Oct 18, 2022 #2 No Because you need 24vdc and that’s on the other side of the connector
roxusa Lifetime Supporting Member OP R Join Date Nov 2008 Location NJ Posts 994 Oct 18, 2022 #3 Thanks, I ordered a cable.
