.XML or .CSV Alarms in Wonderware
BPyles
Apr 2014
Canton Ohio
I have a CompactLogix (v19), 3 Kinetix300 servos and an industrial PC with Wonderware. I am trying to create an alarm screen to display the servo faults. RA servo expert told me that he could provide me with a .XML file of all the fault messages and fault codes plus an additional 2 add on instructions one to create a single fault code and another to trigger a fault in the HMI. I am new to wonderware and am trying to think of the best way to utilize the information provided by rockwell. My initial thought is to convert .XML to .CSV in excel then import it as strings to Wonderware. Am I on the right track? Any other suggestions?
Thanks!
Yes, you can create tags in excel, save a a .csv file, and import into wonderware. Create a new project and then use the tag builder to create one of each type tags, io discrete, io analog, etc. Then export that as a .csv and you can see the format for importing those types of tags. Wonderware comes with excellent documentation that will explain this in detail.
Hi, is there a way to read a CSV or XML file into the Studio5000? Early phase of project and trying to avoid using Omron to read XML file (there...
3,198
Hi everyone, I have an issue, how is it possible to read data from an XML file with Delta PLC? In fact, I have another device (ElectroCell from...
1,148
Hello, I have a project where I need to use a CLX to communicate with a 3rd party device that exchanges data via XML formatted commands and HTTP...
1,717
As per title, I am looking for a way to import the design paths for factorytalk studio. I don't have a personal work laptop but use one of 3 or 4...
2,143
Good Afternoon , When I open FactoryTalk View ME . I go to open it up and I get the following message. " The correct version of the...
995
