yeah/neh on idea for SLC housekeeping idea?
ganutenator
May 2002
kansas
1,440
Problem I am attempting to correct:
Make the SLC work more like the PLC 5 in the way in which oneshots work. In essence, make an ONS out of an OSR. To further expound... The SLC doesn't set their OSR's to one on prescan. The PLC 5 does. The benefit of this is the following:
// This is an SLC. The coil could pulse on first scan even though B3/0 didn't transition from false to true on its own (i.e. an actual discrete photo-eye input but no object went in front of it).
B3/0 B10:0/0 B3/1
--|/|----[OSR]---( )
// This is a PLC 5. On prescan, the PLC writes a 1 to B10:0/0 to inhibit B3/1 from pulsing pre-maturely.
B3/0 B10:0/0 B3/1
--|/|----[ONS]---( )
Idea:
If I reserve an array of words for oneshot useage. I could then set each word to a "-1" on first scan which would set each of the oneshot's memory registers to one. This would be very similar to the way in which the PLC 5 handles oneshots on prescan.
Good idea?
Bad idea?
You worry to much?
More useless time wasted?
You should have posted this as a poll
C. You worry too much.
How often is your PLC getting powered down? Most of my installs either operate 24/7, or
How often do you write a rung where the default conditions are usually false under normal conditions?
I've brought this up before. Should I upgrade my Unity software from v8 to v11? I'm affected by zero software bugs right now. I have PTSD...
1,826
Hello everyone... I have got another customer... (someday it will take more the one hand to count them :) ) they asked me could I make a program...
7,440
I am trying to create an agnostic product queue builder using PLC ladder logic. I have a pallet conveyor and would like to be able to use a NO or...
18
2,237
Hi all, I have been working on a tool for my company that handles a specific task our company runs into often related to PLC's. This is a tool I...
2,890
I asked this question briefly in my previous post long post, I'm asking again here as the main point so it doesn't get buried. I am pretty new at...
1,521
