zebra printer module configuration! PLEASE HELP
Persephone
Aug 2021
there
Hi there,
i have 2 questions, first of all...
I need help with the configuration of a Zebra Printer. zt410
I have created the module and still have no conection. (a little triangle with a exclamation point appears at the bottom of the name)
the second question is for the configuration of A MSG ...
(for send the zpl code to the printer ... i have 4 INSTRUCTION MSG)
whats the instance? .... is the # of the printer.... i didnt get it.
I need to put this printer to work and im lost
PLEASE
Here more inf
Please tell us what you are trying to accomplish.
i helped set up the system where i used to work, but i need more details.
james
Basically when I go online... to test the printing... this ERRORS appear.... im not sure if it is somenthing with the connection... or anything bad with the program...
can you send me an example for connection betweenn the ip printer and rslogix5000.
  • rutina.zip
I am unable to send you any information, i no longer work for that company.
what are you trying to print?
alphanumeric lines, Barcode, rfid?
we had the same issue. what we ended up doing was buying the zebra pro designer software, creating a standard label, then have our software developer create a program that populated a sql table with the information.
anytime the table had a new member, we sent that information to the printer using that label format.
the developer said he had to change some of the commands (that was 4 years ago and i can be mistaken). i do know he did have to alter something about the print command structure. i wish i could provide you with better details.
james
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
385
Hi All, I currently have an issue to establish connection between my PLC to Zebra Printer. On my side don't have the ASCII card Module to use...
779
Hi All Trying to get the PLC to send a commant to the printer to prinnt a lable. evarything is setup except RS linnx cannot see the printers and...
387
Hi All I'm trying to connect two zebra printers to th PLC through Ethernet. I can ping the Printer through my laptop connected to the private...
364
Hello everybody, I have a problem with a Zebra printer, specifically a ZT230. I need to program the printer with Studio 5000, fmw 33. Today, I...
3,459
