Zelio Logic GSM System
safwan
Oct 2008
IRAN
Guys..I have to provide a solution for monitoring the fire Alarm of 20 Villas and client requirement is either Siemens logo or Schneider zelio which should provide the SMS service if the fire occurs along with Buzzer Alarm output.
I just started working on Zelio Plc's and doesnt much aware of that. 24VDC signal will be triggered from Fire alarm panel in case of fire.
Iam considering...
SR3B261B having 16 Digital Inputs and 10 Digital Outputs.
SR3XT101B module having 6 Digital Input and 4 Relay Outputs
24VDC finder relays(20 qty) for VFC
SR2MOD02 - GSM for communication interface
SR2 COM01 - Communication Interface
Is my estimation correct ?
Good afternoon colleagues, a pleasure to greet you. In this opportunity I require some help from you. I am trying to make a shift register in...
2,218
I have programmed a Zelio logic to monitor 3 inputs, and coresponding 3 outputs for controling of 3 pumps. How to pause/resume timers for pumps ...
4,381
Hi. I am, in fact, not an specialist in PLC's but, in my work we remotely access a gear 500 kilometers away and we have observed, after some...
2,531
Hi there, I have a Zelio SR2B121JD and am trying to work out in FBD how to pause a timer. If I start a timer for a 60 second countdown, how can I...
7,252
I have a zelio logic 2 smart relay on an alarm system. The relay is getting no inputs at all yet is showing the coil to be energised and the...
2,525
