Zelio Programming Loop
dcaragher
Mar 2009
Cortland New York
I am LabView programmer and am using a Zelio Smart relay for a simple cycle test. I know very little ladder logic, and am trying to figure out how to get a get my diagram to loop continuously. I have about 6 rungs that execute sequentially, but then I need to repeat the sequence over and over. Any help would be greatly appreciated. You can reach me here:
Dan Caragher
Staff Engineer
Pall Trinity Micro
Pall North Building
3669 State Route 281
Cortland, New York 13045
[email protected]
Phone : 1-607-753-6041 ext 2518
Fax : 1-607-753-1220
www.pall.com
I'm not familiar with the Zelio, but most ladder logic programs automatically re-scan the ladder indefinitely.
When you say that you want your diagram to loop continuously, do you mean that you want the program to re-scan the ladder program over and over again, or do you have a sequencer type program where the cycle test needs to go through a number of steps, and then repeat?
Do you understand what I mean by the differences?
Hi guys, I am new to PLC and I just got this Zelio smart relays. After reading the Help files, I decided to go with the LD programming as I find...
3,516
Hi all, i was wondering if it is possible to control 6 output lights, with a zelio with just 4 discrete outputs, its an assignment and the teacher...
2,804
I have created a washing sequence of five cycles for a storage tank which is located on a farm. As soon as a selection switch is turns turned on...
3,220
i recently learn PLC AB slc 500 and start using zelio smart relay for my own small compactor business instead of timers and relay i used and made...
6,300
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
139
