Zelio Timer Questions
BAMIKE
Jan 2008
PA
I am having trouble with the Zelio Timers. Can anyone help?
I need a program that turn on a fan for 180 minutes then stop for 2 minutes, then turn on the reversing contactor of the same fan for 180 minutes and then repeat until manually stoped .
To be honest I have nothing. I do not understand the timers. I have moved to the FBD to try it. It seems easy, but I cant seem to do it.
once the forward rotating fan times out, how do i start the two minute standby timer. and then again, after the two minute timer, how do I start the reversing contactor for the fan.
It seems like i need the first timer to start the second timer?
This should be pretty much what you need. The only you need to do is put an interlock on the start signal so that when the loop is running it ignores the input.
Jon.
Hi there, I have a Zelio SR2B121JD and am trying to work out in FBD how to pause a timer. If I start a timer for a 60 second countdown, how can I...
7,266
Hi, I am working on my first Zelio project (using Zelio Soft 2) so do excuse my question if it's really simple. I am looking to generate an output...
4,973
I want to be able to pause a zelio smart relay timer, so when the machine is running the timer times, then pauses when the machine is stopped then...
2,627
Bit puzzled with these Zelio timers. Say if I wanted to program a timed sequence in FBD eg Output 1 on for say 1 hour then off then output 2 on...
1,443
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
148
