'Redundant' for SLC 5/05 with Prosoft (MV146-DFNT)? possible?
ckchew666
Aug 2003
Malaysia
591
We have a system setup using SLC 5/05 CPU, the question is can we add a redundant/backup ENET using Prosoft MV146-DFNT? So at the same time bothe the 5/05 and MV146-DFNT will transfer data to the HMI/SCADA. So when the 5/05 comm is lossed (line broken) then the HMI will pull data from the MV146-DFNT.
If anyone done this before, can you please let me know how's the addressing goes?
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
Hi guys, in a redundant dh+ network consisting of one IO scanner (1747-ASB) having a combination of different IO modules in a 13 slot chassis...
3,508
Hi, I am building a SLC redundant system in which i have to make analogue output redundant. I am afraid that when the load will be shifted from...
2,484
dear i am using 2 controller rack of 4 slot. 0 slot using for controller SLC5/4 1 slot 1747 BSN same configuration for the other controller...
2,325
what are the software options, optional packages and hardware to conect one workstation to slc 500 redundant plc
3,119
