Modbus into Wonderware through Moxa
LVShann
Jul 2012
Kentucky
After racking my brain on this one, I think I'm going to need some help.
I've got a system where I have a Moxa MB3270 Modbus Gateway with 11 Eurotherm 2208e units on one port and two 2208e units with a Fuji frequency drive on the other. I've not got a lot of experience with these components but I've got the ports of the gateway mapped for the correct modbus slave addresses and I've got the DASMBTCP set up as far as I can figure.
My issue is on creating the proper device groups/items or proper configuration from the DA server so that I can link tags to the right references in each device. To specify - I'm having trouble in figuring out how to specify for the correct slave address in addition to the typical 4+(4 register digits) to, say, read data.
Thanks.
Hello, I am attempting to add some IO Discrete tags to a AVEVA InTouch project (version 2020). These tags use the MBTCP driver and attempt to map...
1,182
So I am trying to access data from an Eaton PXG900 Power gateway with Wonderware. The gateway can be polled for data by Modscan and does provide...
2,862
I'm creating a new HMI to communicate with a Yaskawa controller. I started adding some of the values to the screen from the 4XXXXX registers and...
2,438
Hello I'm trying to read a register from a Modbus device into Wonderware System Platform. In object viewer it shows the status of being "Good"...
1,919
I about to upgrade all of my computers in the plant to windows 7 machines. My problem is that some of them are running Wonderware with Modbus Plus...
1,464
