Kinetix 6500 questions
taylor1982
Aug 2011
Bavaria
78
Hello,
I have to use Kinetix 6500 servo drives for the first time in a new machine and I have a few questions and I hope you can help me a little bit.
- When I start up the drives (I have two Racks with 5 drives) it lasts about 1 min after they are ready (PRECHARGE appears in display). Is there a information from the data types that the drives are ready and have finished startup? Like a bit in the MOTION_GROUP or AXIS_CIP_DRIVE data types which I can use for switching on the main power contactor to the racks.
- Is there some Sample Code for handling the Kinetix6500 drives? Like for doing an MSO, MSF, MAM, MAJ? I found nothing in the Rockwell sample code library for the 6500 series.
Thank you so much!
Steve
- Is there some Sample Code for handling the Kinetix6500 drives? Like for doing an MSO, MSF, MAM, MAJ? I found nothing in the Rockwell sample code library for the 6500 series...
Have you checked in the RSLogix folder?
C:\RSLogix 5000\Projects\Samples\
Yes I did. There are Motion examples, but I found noting for the Kinetix6500. And the 6500 AXIS_CIP_DRIVE structure is quite diffrent to the AXIS_SERVO_DRIVE structure.
My problem is to understand what all the information in the AXIS_CIP_DRIVE and MOTION_GROUP mean.
For example:
- Which bits indicate that the Rack is ready to switch on the main power contactor (or do you only use the contactor enable hardware signal?)
- Which bits should I use or should be true before doing an MSO, MAM, MAJ...
- Which information I can use for error detection. Do you use the AxisFault or the AxisStatus DINT or the BOOL variables for detecting that the drive is OK
How do you solve this issues. Does everyone knows a sample about that?
Thanks!
I'm a sparkie at a facility where an OEM is debugging a one of a kind machine. I cannot help with your code examples. I can tell you that before we used the contactor enable hardwire signal we lost 4 power supplies in about 8 months.
For example:
Thanks!
I can post some examples tomorrow of what I have done on a 6500 system, but I can tell you that the rack itself enables the main contactor when it's conditions are met.
Examples would be great. The contactor enable signal of both racks is used right now for switching on the main contactor.
Looking forward for the samples!
Greets to NZL. Was there in 2013 for a 4 weeks tour across both islands. It was unbelievable!
Steve
I used the motion accelerator toolkit from AB. Check it out the sample projects helped me out big time for my first Kinetix 6500 / CLX project!
Dear team, We are constantly facing M07 incremental loss on one of our kinetix 6500 safe torque. We have changed Servo motor (MPL-B4530K-MJ72AA)...
112
Loving AB right now... We have an Allen-Bradley 2094-EN02D-M01 Kinetix 6500 servo drive that once had safe-speed monitoring which was eliminated...
133
Hello, I encountered a problem with the kinetix 6500 drive, error code s22, loss of 3 phase voltage. After disassembling and replacing the thermal...
167
Hi everybody, I am having an intermittent issue with a Kinetix 6500 drive. The fault i get is a SAFE FLT 05, described as GuardFeedback1Fault in...
883
A line in our plant has always had an issue where everytime the jar filler stops/restarts, it wastes 5-8 bottles because of underfills. FWIW, the...
1,826
