A-B Kinetix 6500 multiple s22 Fault
godzilov
Mar 2024
USA
Hello, I encountered a problem with the kinetix 6500 drive, error code s22, loss of 3 phase voltage. After disassembling and replacing the thermal paste in the drive, it became better, but after a day of work the error still appears. Moreover, sometimes the frequency is every minute, several times in a row, and then it can work for 8-12 hours without this error. The 400v voltage in the network is fine, the inside of the drive is also without visible damage. Has anyone encountered this and how did they solve the problem, the results of a search on the forum did not solve the problem, thank you?
According to the manual fault S22 means: All three AC input phases are detected as absent when an axis is enabled.
Axis was enabled when main(three-phase) power was removed.
The remedy is to disable axis before removing power.
The error occurs while the equipment is running, and not before it is turned off.
Dear team, We are constantly facing M07 incremental loss on one of our kinetix 6500 safe torque. We have changed Servo motor (MPL-B4530K-MJ72AA)...
112
Loving AB right now... We have an Allen-Bradley 2094-EN02D-M01 Kinetix 6500 servo drive that once had safe-speed monitoring which was eliminated...
133
Hi everybody, I am having an intermittent issue with a Kinetix 6500 drive. The fault i get is a SAFE FLT 05, described as GuardFeedback1Fault in...
886
A line in our plant has always had an issue where everytime the jar filler stops/restarts, it wastes 5-8 bottles because of underfills. FWIW, the...
1,826
Customer is moving machine, and down sizing it. It has a 6500 rack and they will be removing 4 of the servos. Can I put the slot fillers in the...
1,437
