Kinetix 6500 slot fillers
mf8560
Aug 2015
ohio
Customer is moving machine, and down sizing it. It has a 6500 rack and they will be removing 4 of the servos. Can I put the slot fillers in the middle of the rack where these are, or do I need to move the remaining units to the left so the slot fillers go on the end?
If so it would make it easier, wouldn't have to move a lot around on the rack and readdress drives in the program. But, I could only find in the manual that that the fillers need to go to the right of the module.
I had a look through the RA knowledgebase and they basically say don't put slot fillers in between axis modules because the added distance can cause electromagnetic Interference and impedance.
ID: QA3936 | Access Levels: TechConnect
They do state in another technote that you can use a slot filler for testing purposes which I have done before on a 6200 system.
ID: BF5884 | Access Levels: TechConnect
Alan.
Dear team, We are constantly facing M07 incremental loss on one of our kinetix 6500 safe torque. We have changed Servo motor (MPL-B4530K-MJ72AA)...
112
Loving AB right now... We have an Allen-Bradley 2094-EN02D-M01 Kinetix 6500 servo drive that once had safe-speed monitoring which was eliminated...
135
Hello, I encountered a problem with the kinetix 6500 drive, error code s22, loss of 3 phase voltage. After disassembling and replacing the thermal...
170
Hi everybody, I am having an intermittent issue with a Kinetix 6500 drive. The fault i get is a SAFE FLT 05, described as GuardFeedback1Fault in...
887
A line in our plant has always had an issue where everytime the jar filler stops/restarts, it wastes 5-8 bottles because of underfills. FWIW, the...
1,828
