Connected components workbench: HMI Trends
blackbird307
Jun 2015
Winnipeg
59
I am trying to configure a trend in connected components work bench. It displays the x-axis with T-# from right to left, and displays the current time at far right. For some reason I can't see an option anywhere enabling me to change this. Further more, I can't find anything in manuals pertaining to this.
When I enable log trend onto storage device, the pen doesn't move anymore on the trend itself, however it still logs on my storage device without issue as far as I can see. But I can't visually see what's going on in the HMI. The pen is stuck and doesn't progress over time.
Now I am having another problem.... I can't log more than one trend.... I get an bland non descriptive error message "Property value is not valid" when I select trend storage location on an additional trend. If I remove trend storage location on other trend, and then add storage location on this trend, I don't get error message. I haven't looked at the specs relating to this, so I am not sure yet whether this is a limitation.
I have 4 trends.... Am I going to have to merge them all in one? This could be a problem because the ranges are substantially different, IE, range in low 10s mixed with range in high thousands. I won't be able to see range in low tends since my y-axis is so large.
Can anyone help me?
Thanks!
There is a setting in the trend properties that allows you to log while screen is not active which is false by default
I checked that it had no effect on any of the other things. I also don't like the fact that the trend graph doesn't show the date. As far as the log file I have not been able to find a workaround. Like Blackbird 307 I also need to have multiple Trends going at once with different scales. I don't think this is going to work for me unless they have come out with some kind of add-on for the trends.
was trying to use Connected Components to connect to a 525 drive via usb with the face off but can't seem to connect to it. the screen lights up...
838
So I'm using CCW to program a panel view and this is not my first I have done many. My Problem is I get an error message that I have never seen...
517
How do you expand a branch in connected components workbench. Example i want to add an interlock around more than one contact. Most software you...
1,307
I’m working on a conveyor project for work. We’re trying to install a few diverts to carry product directly to one of two trailer doors. I have...
1,084
I cannot get CCW to add a controller, i keep getting a error message saying that the device is not authorized. This happens with any model and...
1,418
