titi_nicolas
I am trying to program a PLC code on a CX9000 with TwinCat.
I spent the last days configuring the hardware and I think it is fine. I found some interesting tutorials on Youtube on how to connect and configure a CX device and I strictly followed them.
What is working so far:
- I can ping the CX.
- From the System Manager, I can connect to the CX and find the plugged terminals.
- I can map my variables to the physical terminals.
- The status bar in the System Manager says "Config mode" or "Run %" (i.e. no "Timeout" that would means that there is a connection problem).
Nevertheless, when I try to Login to the CX from TwinCat, I get an error message "Wrong PLC type connected". But the status bar at the bottom of the panel says "TwinCat Running" and the target field displays the correct device.
Moreover, I can also get an other error message "TwinCat run-time already running" if I try to login.
I could not find any help in the manual or the web regarding those error messages.
Does anybody can help me?
Thank you very much.
