Is RSlogix Micro Starter Lite Still Available?
Aggregateman
Apr 2017
michigan
23
Well, the title kind of speaks for itself, but I'm curious if the micro starter lite version of logix 500 is still around, every link I've tried comes up broken because of AB redesigning their website over the years, I've got logix5000 for my compactlogix but I need to sketch out something to deal with an older SLC system, but someone else has our laptop with that software on it, it would be helpful to have, I know its not compatible with SLCs but I just mainly need to be able to sketch stuff out on it then send it to him to copy.
Thanks!
I sympathize. I know exactly what I'm looking for, but the Product Compatibility and Download Center makes it very hard to find it.
Start with the PCDC
https://compatibility.rockwellautomation.com/Pages/home.aspx
Type "RSLogix Micro Starter Lite" into the Search field.
When the result comes up, select "Add to Download Cart", not "Downloads". The Downloads link takes you to the MicroLogix firmware, not to the RSLogix 500 Micro Starter Lite download.
When you are done, be sure to use the "Send Feedback" mechanism to let them know what you think of the ease-of-use of the website.
Start with the PCDC
WOW, thanks! I had exhausted my google-fu and the Allen Bradley website usually gives me headaches if I am searching for anything other than user manuals. Hopefully this post helps out many people that stumble upon it!
Start with the PCDC
FYI
Actually you can click on download, then "Select Files" next to 11.000 or 10.000 this will get you to Micro starter lite and several other utilities.
https://compatibility.rockwellautom...17&q=RSLogix Micro Starter Lite w/o RSLinx EN
Hello, first assignment with A-B stuff. The CPU is a MicroLogix 1000. Have a serial interface, so RS Linx Classic to edit the driver (AB-DF1) with...
1,693
Oh, I hope someone can help! I have one little problem holding me up from studying this weekend. I'm using Rslogix micro starter light, it's a...
2,991
I am using RSlogix Micro Starter for a personal project and currently have it installed on a desktop computer. Soon I will be moving my project...
2,204
I've created a test program in Micro Starter Lite and attempting to set up communications with the emulator and run the program. In the...
1,578
Hi, I am new to Allen Bradely PLCs. I am trying to communicate the RSLogix Micro Starter Lite and RSLogix Emulate on EMU500-1 driver (no...
4,307
