RSLogix Micro Starter on 2 computers
mikeexplorer
Supporting Member
Nov 2018
Scranton,PA
179
I am using RSlogix Micro Starter for a personal project and currently have it installed on a desktop computer. Soon I will be moving my project and will need to install it on a laptop.
Once I do this, the desktop copy is no longer needed. Do I have to purchases another copy or can I just move it? There would never be a case where both would be in use at the same time.
Mike
What is the PLC you are communicating to ? they have a free version for the 1000 and 1100's
But you should be able to move the key from one PC to the other, but this also depends on how old of a version/key you have
RSLogix Micro is licensed as node locked, and you are limited to re-hosting it a couple of times per year (4 or 5 max).
I seem to recall inquiring about putting it on a license server and was told that isn't allowed (our customer was using the Developer edition). In our case, it was not a big deal, so we moved the license to their maintenance laptop permanently.
If you require the starter edition (not Starter Lite), and plan to use it on both machines, I think you'll need to buy a 2nd copy.
Micrologix 1400 so I am using a copy of RSlogix Micro Starter which was not free.
Right, but to do that (legitimately) requires rehosting.
https://activate.rockwellautomation.com/ActivationHelp/343781.htm
And the latest info in that link says that you can do it 3 times per year with the automated process.
If that is the case, it would work for me. Right now my copy is on a desktop as I have been developing my model train project on the floor of a spare room. I plan to transfer the project to my around the ceiling layout in my living room so I would need to move my copy of RSLogix Micro Starter to a laptop. I would only need to do this once and I would still only have one active copy of the software (The desktop would not need it anymore)
Mike
Hello, first assignment with A-B stuff. The CPU is a MicroLogix 1000. Have a serial interface, so RS Linx Classic to edit the driver (AB-DF1) with...
1,695
Oh, I hope someone can help! I have one little problem holding me up from studying this weekend. I'm using Rslogix micro starter light, it's a...
2,991
I've created a test program in Micro Starter Lite and attempting to set up communications with the emulator and run the program. In the...
1,580
Well, the title kind of speaks for itself, but I'm curious if the micro starter lite version of logix 500 is still around, every link I've tried...
12,412
Hi, I am new to Allen Bradely PLCs. I am trying to communicate the RSLogix Micro Starter Lite and RSLogix Emulate on EMU500-1 driver (no...
4,313
