Help - RSLogix Micro Starter Lite
swedeleaner
Dec 2013
Göteborg
143
Hello, first assignment with A-B stuff.
The CPU is a MicroLogix 1000.
Have a serial interface, so RS Linx Classic to edit the driver (AB-DF1) with COM-port and speed. If everthing is correct i should be able to Go Online in RSLogix Micro?
How do i perform a complete backup now?
PLC-program, registers, hardware settings etc.
DO I use Comms-->Upload to do a complete upload in RSLogix Micro?
Does RSLogix 5000 use RSLinx Classic as well?
Or how do you setup communications in RSLogix 5000?
Watch the video is shows you step by step...
Yes RSLinx is the communication software and RSLogix 5000 is the programming software
5000 will not work on a 1000, you must use RSLogix 500 or the free Micro Starter
5000 or Studio is for CompactLogix and ControlLogix
No you will need the full version of RSLogix 500, they have several different versions, I think they start around 1000USD for a version that will work with the 5/03 and the PRO version cost around 4,000 last I check.
Hello guys, First post here. Started working on PLCs yesterday haha. A class I took in school gvae me a general idea, but the chapter lasted a...
3,748
HI All, I'm having problems communicating with my Micrologix 1000 PLC. I have Windows 7 Pro 64 bit on my computer. I have RSLinx 2.54 and...
21
10,232
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
578
Hello Everyone, I have tried to access the help function from my RSLogix 5000 but everytime I select a function block on the PLC rung and press...
1,279
I’m working with indirect addressing and trying to make an HMI where each Rectangle Object has a tag of “A[0-127]” with a correlating Push Button...
4,211
