1734-AENT Module Status solid red
Kataeb
Jan 2007
www.livelovelebanon.com
636
Kindly, we have the following module with its Module Status led solid red.
What can we do to solve this?
" POINT I/O EtherNet/IP Adapter Module , 1734-AENT , Rockwell , series A revision 2 "
In the manuals it is mentioned the following probable cause.
If we download its firmware again will it help?
" Firmware fatal error present. [Unrecoverable fault has occurred: Self-test failure present (checksum failure, or RAMtest failure at cycle power).] "
we downloaded the firmware, but got below errors. see also attached. what do they mean? thank you
[FAILURE] Device Identity: Error #11002: Unknown Extended Status error code received.
GS=0x01, ES=0x0312
[-------] Device Identity: Error #10005: GetAttributesSingle to Device object - target does not support hardware revision.
Error #11009: Attribute Id not supported.
GS=0x14
[FAILURE] Reset: Error #11003: Unconnected Send timed out waiting for a response.
GS=0x01, ES=0x0204
As already stated, the module is "broken", as indicated bu the solid red module status LED....
Replace it and don't waste any more time.
Hi, I just bought a 1734-AENT Series C module (Revision 6.01). I am using RS logix5000 and at site we have a running system with control logix...
16
8,869
Question on the 1734-AENT/B module (v5). I have a 1769-L35E (V15) and I was working on adding 1734-AENT/B module to the I/O Configuration tree in...
3,639
Kindly, we have the following module. POINT I/O EtherNet/IP Adapter Module , Catalog Number 1734-AENT , Rockwell It is series B and revision 5...
3,503
Good Evening , I have a CompactLogix 1769-L18 ,with a 1734-IE4C beside it and I am remotely adding a 1734-AENT, and on the side of that I am...
2,096
Hi, We are seeing a problem on our Allen Bradley Ethernet Point IO modules (1734-AENT Module) to our L72 controllers, where if there is a network...
2,319
