Vodoo Member V Join Date Nov 2016 Location Wauwatosa, WI Posts 5 Nov 18, 2016 #1 When I try to run FactoryTalk View Studio it fails and this error pops up; FactoryTalk Studio Cannot connect to addin object Name: Application Handler Cause: 80004005 Any ideas?
bright676 Member B Join Date Nov 2012 Location va Posts 494 Nov 18, 2016 #2 I have had the before, dont know why though, Do a repair on ftvs services platform, that always worked for me.
Vodoo Member OP V Join Date Nov 2016 Location Wauwatosa, WI Posts 5 Nov 18, 2016 #3 I have done uninstall and reinstall with no luck. I am going to uninstall all things Rockwell and do fresh installs. The repair didn't run through so something is wrong there.
phuz Member P Join Date Jun 2008 Location Mohnton, PA Posts 1,044 Nov 18, 2016 #4 Cause 18 QQProtect (a security software originating in China) has blocked FactoryTalk View Studio from running. The error displayed is: Cannot connect to addin object Name : Application Handler Cause : 80004005 Solution 18 Stop the process named qqprotect.exe from Task Manager, or uninstall QQProtect.
Vodoo Member OP V Join Date Nov 2016 Location Wauwatosa, WI Posts 5 Nov 18, 2016 #5 Looked and I could not find this QQProtect in either Services or Programs
Steve Bailey Lifetime Supporting Member + Moderator Join Date Apr 2002 Location The boondocks of Western Massachusetts USA Posts 8,601 Nov 18, 2016 #6 It could be insufficient privilege. Try running FTView Studio as administrator.
Vodoo Member OP V Join Date Nov 2016 Location Wauwatosa, WI Posts 5 Nov 18, 2016 #7 I just uninstalled FTView Enterprise. REBOOT, REBOOT REBOOT. LOL
bright676 Member B Join Date Nov 2012 Location va Posts 494 Nov 18, 2016 #8 I never did the uninstall/install, I just did the repair under installed programs.
Vodoo Member OP V Join Date Nov 2016 Location Wauwatosa, WI Posts 5 Nov 18, 2016 #9 I tried that but it failed to go through the repair
bright676 Member B Join Date Nov 2012 Location va Posts 494 Nov 18, 2016 #10 When I did it, I closed everything first, nothing running in the back ground. If that helps.
Jonathan1018 Member J Join Date Jan 2017 Location Plehatchie, Ms Posts 3 Feb 6, 2018 #11 Had the same problem. Remove, and restart the computer after each uninstall. Uninstall updates KB4058702, KB4056892, and KB4054517.
thefreeauction Member T Join Date Oct 2010 Location Nebraska Posts 4 Feb 23, 2018 #12 I had the same exact error - Windows 10, FactoryTalk View Studio V9. My issue occurred right after Windows made an update. bright676's fix to repair the FactoryTalk Services Platform & do a reboot worked for me.
