Recommend Modbus and HART cable
cncsparky
Dec 2014
Ks
98
I have a task to connect devices to a Control Logix PLC. First time working Modbus and HART from scratch.
Like to know if I can use the same cable for both the Modbus RTU and HART devices? Looking at Belden 3106A.
Siemens MultiRanger 100 level control. Modbus RTU 2wire multidrop. Eight devices, about 150M from end to end.
Foxboro 875 PH meters. HART 2wire single drop. Max 50M from each device to PLC.
Can I use the same cable for both, or does anyone have a recommendation?
Thanks!
Thanks!
I'd agree that the Belden 3106 is an excellent choice. Correct impedance, with a good jacket for tray application.
Near perfect for RS-485:
- third wire for signal ground
- 120 ohm impedance, easy to terminate with common 120 ohm resistors
- super shielding - braid and foil
The shielding and twisted pair will work perfectly for 4-20mA or the transducer-Multiranger connection.
I agree, an excellent choice.
Good Morning , I have worked with many robot integrators through the years ,and was looking at Pearson Packaging Systems . Have many of you used...
2,203
Hello PLCS.net! I'm about to program my first Robot soon! It's going to be a Fanuc. But wait, there's more! It's also going to be collaborative...
3,359
I need to do some simple schematics, I don't need (and would never use) 3D modelling rendering etc. For those with long memories, AutoSketch would...
20
8,492
Hello all, Is any good analyzing software. We have a bunch of data in text files. Need to analyse. Right now we are using DIadem. Is there any...
2,278
Can someone recommend me a compact device to control logic on/off beacon according to signal from a PIR ? Some RTU maybe. I am newbie in...
2,191
