RSView ME AOA Initialize Failed
mollyputzer
Apr 2006
Waldo Wi.
I have a new copy of RSView ME and when ever I try to open the tag database, I get the following error:
"AOA: AOAInitialize failed"
I have called tech support, no help,
Uninstalled and reinstalled, no help,
checked tech notes on-line, no help.
Has anybody seen this and solved the problem.
Thanks much,
Mollyputzer
rdrast,
The bottom tech note about decompressing the hard drive is the one that I did not find on their website, but it is the one that worked.
Thanks much for your help
mollyputzer said:
rdrast,
I have the same problem, but my drive is not compressed! Any Ideas?
Edit: I have version RSView Studio ME 4.00.00 (CPR 7)
I have almost always recovered from this error by using the Application Manager to backup the application (create the .apa file) and then restoring the application with a new name.
I've seen this error many times and this has almost always fixed it.
OG
OG
Thanks, I will give that a try... Do you happen to know the cause of this problem?
OG
That did not work... I backed up my app, and restored, but still have the same problem. I even did this with a sample program and same results... I don't know what to do...
Error "AOA: AOAInitialize failed" when trying to open tag database in RSView Studio application.
Answer
Problem :
Error "AOA: AOA Initialize failed" when trying to open tag database
It is possible that tag database is corrupted , but deleting RDMDATA folder and rebooting PC did not help
RSView Studio works fine with another application on the same PC.
Workaround :
Start a new application -select IMPORT
select RSView Studio med file , and navigate to the problem project, select med file , finish .
The project is recreated and database is OK
Problem: Error "AOA: AOAInitialize failed" when trying to open tag database
Answer
Problem :
Workaround :
THis did not work either... :mad:
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
333
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
281
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
828
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
808
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,432
