Importing AOPs on RSLogix 5000 version 20.01
jakeparsons03
Jun 2017
Indiana
78
I have been trying to import the AOP for a 1769-AENTR. I downloaded it off the RA website and it gave me a .exe file. After running the .exe I closed logix and reopened it but the AENTR isn't on the list as modules I can create. Am I missing some sort of import method? The .exe created a .dat file. I haven't seen that before, is that the file I am supposed to import?
Where in the hardware tree are you trying to add it? The tree hierarchy will filter out some modules giving an impression it is not available if you didn't right-click on the right spot.
What processor are you using and what version is your program? I wouldn't think that module would be an issue, but there are modules that will not work under older versions. When that is the case, I believe the module will not show up as an option.
And, after extracting the archive, you opened up the RACompactAdapter_V9.06_Rel folder, right-clicked MPSetup (no extension!) and chose 'Run as administrator'?
I didn't. I saw that but I thought it was apart of a previous set of AOPs I failed to download. I ran it and it worked! You are the man/woman! Thank you!!
It happens when using RA products...They should try standardizing their install packages, especially the web downloads...
Hi! I am at my wits end and can't find any resources to help fix it so: I have a program I am importing from another computer that is WW2014...
59
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
524
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
406
I am working on trying to send and receive lists of BadgeIDs and User Access levels from a windows application to my system. My current theory is...
630
Hi all, I am doing a side project where the HMI will play an mp4 file when a certain bit turns on when I toggle it from the PLC(384kb dig I/O)...
1,248
