1756-DNB with 1734-ADN
phuz
Jun 2008
Mohnton, PA
1,046
I'm playing around with some DeviceNet stuff on my test bench and just got a 1734-ADN. I forgot the ADN was AutoBaud, so that's a nice feature. I have a 6' cable between the two adapters with terminating resistors. When browsing in Linx, I can see the 1734-ADN as well as a single IO module that I have installed (1734-IA4). However, when I scan the network in RSNetworx, the adapter shows up (node 11), but no IO modules.
Are you using a licensed version of RSNetworks, or Grace Mode/Demo.
It's been a long while since I had dealings with DeviceNet and RSNetworks, but I believe the unlicensed (unactivated) version will only allow up to 6 nodes. Whether this means nodes 0 to 5 or not I cannot remember.
There is also a setting in RSNetworks that limits the scan... that may be stopping your I/O module at node 11 being seen if it has been set below 11
No, it's fully licensed. It turns out that I needed to add the device bridging file to make it work for the ADN's own internal DeviceNet. I never remembered having to do this before and I looked back at the only project I've ever done with DeviceNet PointIO and we used the 1734-PDN (passthrough module). Taught myself something new. 🍻
Hi phuz,
I'm glad to hear that you got their yourself. I had actually read your post late last night and said I'd reply you some time today, if I had the time - to outline the bridging file you required for this setup.
Either way, and as you have not outlined exactly what you did, here is a link to some more info on the setup, should you or others wish to know more...
Adding Point I/O to an existing Devicenet Network?
Regards,
George
Hi phuz,
Regards,
George
Thanks for the link. (y)
Hi everybody, I have with me the following: 1. 1756-L73S controller + 55L7SP safety partner 2. 1756-ENBT 3. 1756-DNB 3a. 1791DS-IB8XOB8 3b...
2,268
Hi good day PLC Talk Community. Can somebody please shed light on 1756-DNB Diagnotic Counters and what they mean. DNB Scanner Diagnostic...
603
Hello, PLCS.net guys. Currently I'm making the safety communication on 1756-DNB to DX200 Yaskawa contoller. I made the setting and assigned the...
635
Numatics devicenet module G2-2 is replaced with new unit and address is configured from address 63 to address 1. Encountered error E#77 for Node 1...
1,046
i'm trying to interface a 1756-dnb to a couple devices. i've got the rsnetworx configuration complete and dowwnloaded to the device. when i go...
3,219
