1756-dnb error
Feb 2020
san antonio
i'm trying to interface a 1756-dnb to a couple devices. i've got the rsnetworx configuration complete and dowwnloaded to the device. when i go online in studio 5000, the scanner is faulted out. the code is "16#0108 connection request error: connection type (multicast/unicast) not supported".
what could be going on here? i'm using an l72s cpu and a 1756-dnb/a
Is the 1756-DNB in the local chassis with the controller, or in a chassis connected over ControlNet or EtherNet/IP ?
If it's in a remote chassis, do other connections to that chassis work ?
What is the RPI of your connection to the 1756-DNB ?
Have you tried de-selecting the Unicast checkbox for the DNB connection (if it's over EtherNet/IP to a remote 1756 chassis) ?
Does your Major Revision in the 1756-DNB object in the I/O tree match the actual module ?
This is unlikely to be a DeviceNet related issue, but rather a matter of the ordinary connection between the CPU and that 1756-DNB module.
it is in a local chassis. rpi is 20 msec. the module revision is correct.
the label on the module say 3.010, but the firmware appears to have been upgraded to 7.003. i have tried with both revisions in the software.
Hi good day PLC Talk Community. Can somebody please shed light on 1756-DNB Diagnotic Counters and what they mean. DNB Scanner Diagnostic...
567
Numatics devicenet module G2-2 is replaced with new unit and address is configured from address 63 to address 1. Encountered error E#77 for Node 1...
1,033
Hi guys, First post here but i really need your help on this Devicenet communication error. I have 5 electrical panels wired the same way, but one...
2,827
I have a customer who has 2 DeviceNet scanners (Series A, v3.8 firmware) in a ControlLogix rack that have been running for about 14 years. In the...
2,542
Hello, I installed a brand new 1756-DNB card and I proceeded to set the node address. To do this, I pressed and held down the manual config button...
2,130
