WinCC project reading STEP 7 project symbol table
Pandiani
Apr 2005
Tz
725
Hello,
I'm afraid I need your help again. I have STEP 7 project and installed WinCC 6.0 demo. I manage to make a simple visualisation system. I have added new communication driver (S7 protocol suite) and took all steps from manual WinCC Getting Started. I created process tags and WinCC project and STEP7 PLCSIM can communicte and binary values from STEP 7 program is displayed in WinCC project. However I've read somewhere that there is no need to create external tags to take values from process, but rather to allow WinCC project access Symbol table in STEP 7 project.
I'm trying to do so. In graphics designer I've chosen View->Toolbars, checked tags and all that but STEP7 Symbol server is empty. I'm trying to create process tags automatically i.e. to make my WinCC project read STEP 7 project and simply take inputs and outputs directly from STEP 7 symbol table. Problem is that WinCC cannot find any STEP 7 project. How to integrate WINCC and STEP 7. They can communicate witouth any problems through MPI add2 (PLCSIM) but I needed manually to create external tags and to associate them with STEP 7 project inputs and outputs. Maybe I need to perform some settings in my STEP 7 project but don't know...
I'm not sure if I explaind what I want but in short:
How can my WinCC project read inputs and outputs from my STEP 7 project and use them like tags without need to manually create process tags?
Does anyone can help me?
Thank you very much for your effort
It's possible but not recommed. Use PCS7 if you need integrated controls & visualisation.
When installing WincC you must check some options on. I don't have the installation CD's at the moment but you should be able to figure out when looking. Also better read IntegrationS7.pdf which is included in the documentation;
HTH
West Vloamse complimenten
Hi, I appreciate any help to make connection between AB DF1 Micrologix 1200 and WinCC Adv project (PC station - not HMI) possible. For now I can...
631
Hi, Im trying to open an old old Siemens WinCC project. It doesnt have to run i just want to look at the project in WinCC explorer. Its...
729
We converted the WinCC project. But it was difficult. A lot of scripts were running in the background. The only problem at the moment is...
563
Hello everyone, is it possible to make a project that will not be used at the end of the specified date with wincc flexible?
2,034
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,361
