PLC software testing
funfun66
Nov 2011
detmold
Hello...
Can anyone suggest me what are different methods used for testing PLC software. also where can i find tools for PLC software testing.
regards..
funfun66
Hello...
I want to know apart from simulators what are other methods.
there is no particular type..i need it generally for all.
also please tell me what are the tools available for these and where can i find it.
Regards
funfun66
Syntax checking should be part of your developer, other than that the only reliable method I know of is to have an expierenced Engineer review the code. Short of this all testing is either on a simulator or at commissioning.
May be a good project for an industrious and creative programmer.
1. In put the process sequence of operations.
2. Add BOM.
3. Read the logic.
4. Verify end results.
Sounds simple enough.
Would you need verbal or ASCII input for this and would you want the output UL and CE certified?
Hello...
Regards
funfun66
Aha, you want a magic tool that analyzes whatever program you write?
Well, then we are two.
Kalle
Kalle
I have written a program that analyzes the PLC program. It makes sure all IO is used in the program, and generates tables of constants, operator settings, event/alarm/trip conditions, and documents the interface between the PLC and HMI. It saves me from having to update documentation if the program has to be changed, and saves me from generating these specifics in the first place.
I recommend creating a good convention and structure for the parts of the program you want to automate the documentation or test-plan generation for as the program you write to parse your program will only be as good as you are at following the convention you create.
hii..
thank u all for your replies and suggestions.
but can you tell me wat is difference between virtual commissioning and simulation, as i find that both are doing same job.
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
180
153
I have downloaded COMMGR 1.15 software on my laptop. After downloading it works. When I stop and start the program again it doesn't work. It is...
176
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
154
Hi All, How do I set a password to PLC using Proficy machine software 9.5-9.8 or some other way? I as using Emerson CPE305 CPU. Thanks.
400
