Melsec Medoc 2.5
Rheinhardt
Oct 2003
Pretoria
39
Help guys,
Mitsubishi o_Oo_Oo_O ...well enough said. After chasing my tail between GX Developer,IEC GX Developer i have found out i have software that was written in Melsec Medoc 2.5.
Are these versions still available???? I used a MS-Dos version years ago cant even remember the version. All the forums i'm reading on this is dating back to 2001...
Does anyone know of any updates on this package that i can use.. Maybe Melsec Medoc Plus??
Help guys,
GX Developer will import Medoc programs, i cant remember how to do it as i havent used Mitsi for a few years now, i am sure somebody will be along in a minute that can tell you..........
To import a Medoc programe into GX Developer you must first create a new project with the correct PLC type. Once you have a project the options to import will be available in the file menu. Most programmes can be imported straight from the Medoc file but this will sometimes fail, especially if there is a very large name list. If this happens then you need to generate a Medoc print file (but, of course, you need Medoc to do this). The print files can usually be imported even if the actual programme file cannot.
Andybr
Thank you
I have actually tried doing the import, with no success, what is the proper file extension for Medoc program? It cannot even see the files.. Some users on the forum and our local distributor says the software was done in the IEC version of GX Developer,
http://www.plctalk.net/qanda/showthread.php?t=46423&highlight=mitsubishi
but the company that did the project +- 2 years ago say Melsec Medoc 2.5. which is not available locally.
I will specify the file types again.
custom.sys okb
edm.edm 2kb
lryboxes.sys 1kb
softctrl.pro 3,360kb
Would i be able to upload the project into GX Developer if the program was done Medoc 2.5? What would the result be in terms of configuration, comments,symbol lists?
At the point of No return!!!
Thanks again
The files you have listed are definitely not Medoc files. The IEC version of GX Developer was originally marketed as Medoc Plus and this could be where the confusion is coming from.
Thank you for all your help and assistance!! I will download the IEC GX Developer Demo and hopefully get some succes..
I will get back to the forum after i have done this.
This one almost went the same way...glad we got it going though.... Just to many software packages for the mitsubishi hardware... makes it a nightmare.
Hi all!
I know I am bringing an old post back.. but I need to open an old Mitsubishi FX1N program which I think was programmed with Medoc!
Anyone still have the program?
Or even better, if someone is able to open my program backup, convert it, and send it back in a GX Developer version.. would be really appreciated.
Best regards,
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
383
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
515
Is it possible to backup the devices (D,M L etc) in MEDOC? I´m going to change the battery and would like to backup before the change. The CPU is...
1,057
Good day everyone, sorry i know this is old but i would like to receive your help with DOS MEDOC SOFTWARE or WIN version if somebody has it...
5,134
Hi, I didnt thought i would come across an A1N CPU in my life. But now i have and it is as i thought programmed in MEDOC 2.4.🙃 Is it...
2,975
