MELSEC A1N-CPU and MEDOC need some help!
Jim.M
Dec 2008
Sweden
77
I didnt thought i would come across an A1N CPU in my life. But now i have and it is as i thought programmed in MEDOC 2.4.šŸ™ƒ
Is it possible to program this CPU with GC IEC DEVLELOPER 7.04.
I need to convert the MEDOC PLC program to Developer..
And im a bit unsure about the programming cable.. its an SC-05N cable?
Help is apriciated.
I am not sure about IEC Developer but in plain GX Developer there are two ways to import a Medoc programme. For most programmes the simple "import from Melsec Medoc format file" will work but on more complex projects it is sometimes necessary to use Medoc to print to a file and then "import from Melsec Medoc format file (printout)". If this is necessary Medoc will run in a dos box on windows at least up to XP (I have not tried it on a later version) and the only problems tend to be with comms. Using the print functions should not be a problem. In the UK the required cable is an SC-09 but this looks the same as your SC-05N so it could be the same thing.
Thanks for info: I managed to convert the progra into IEC GX Dev.. Via Print..
No I need to convert it to Ladder.. hmm.. Cant find GX Converter any where.. :(
With GX Developer (not IEC) you can connect directly to the cpu (with SC09) and upload the program in ladder.
I don't know if IEC can do that too as I don't have it)
Ahh so i can upload program in ladder.. thats new info.. I can try.. I can make it a try.. Would save some time instead of re writing this whole thing :)
Is GX Developer free these days?
A harware question about A1N CPU... I have a spare CPU... but does A1N need a rack to work? I have a spare CPU and it get power but no CPU in RUN.. cant connect to it.. I suspect that i need the back plane?
GX developer is about Ā£700 - or Ā£800 with SC09 cable.
I would have thought you should be able to communicate with the A1N without the back plane as it has it's own power supply....... but I don't think I have ever done that.
Got it to Work wonderful!!
.. SC-05N cable works with serial to USB converter and A1N CPU..
Thanks for all help
Hi, I have an old MELSEC A1N that I have on my desk. Im trying to contact it via my SC-05N cable without backplane. Im using MEDOC. I have...
1,605
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
133
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
386
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
518
Hi I have a Melsec FX1S-20MR, which has been programmed. I would like to copy the program to a new FX1S-20MR? What are the possible ways to do...
628
