Phoenix Bus Modules
randy
Supporting Member
Apr 2002
158
We are having problems with replacement Phoenix InterBus Modules.
Type: IBSL BOX 24 D14/4 M12
4 DIGITAL INPUT 24VDC
Form my understanding they do not made this unit anymore. They also do not supply a replace. We would have to replace the entire bus system with new in order to stay with the Phoenix system.
Does anybody have some used modules you would like to unload?
Randy,
Last place I worked we had some interbus issues and calling there help line in Pennsylvania, bent over backwards to help us. Try this number, [font=arial,helvetica,sans-serif] (800) 808-7177 and they should be able to point you in the right direction.
George
[/font]
I am stuck on fail ctrl error 1013 cannot get IP nor can do firmware update need help pls urgent
241
I re-did a machine for a customer, which had Yaskawa MP2300Siec w/ 5-axis and Phoenix Contact Ethernet/IP I/O. According to the drawing and the...
1,833
Hi, I am using Phoenix Contact ILC 191 PLC for the first time. It has a built-in Modbus Server which works well for integers but I cannot get it...
2,134
Hey All, I am trying to get a Phoenix Contact ILC171 to communicate with a Siemens CU320 via a profibus module (IB IL PB MA-Pac). I currently...
5,940
Hi everyone, I am trying to read and write data using the following setup: -Prosoft MVI69PDPV1 -AOI from Prosoft that does comms for the PLC...
3,866
