Phoenix Contact SBT and AB PLC on Profibus
jmveerkamp
May 2012
OH
23
Hi everyone,
I am trying to read and write data using the following setup:
-Prosoft MVI69PDPV1
-AOI from Prosoft that does comms for the PLC
-Phoenix Contact profibus coupler IL PB BK DP V1-PAC
-Phoenix Contact Safety Bridge Technology I/O (1 LPSDO and 1 LPSDI)
-AB CompactLogix 1768-L43
I setup the profibus using Prosoft's software, Profibus Configuration Builder. Using this software I am able to see the my SBT I/O.
From here I created a test SBT routine in SAFECONF (exports as an AOI).
Then I used some AOIs from Phoenix Contact to try and read/write/operate the SBT I/O.
Currently the SBT I/O has no program in it and this is where I am running into an issue. The AOIs ask for offsets for each device for where to read/write from and I think this is why the SAFECONF file isn't downloading to the I/O modules.
Does anyone have any experience doing something like this? I have talked to Phoenix a few times and so far they have not been able to figure anything out either. Phoenix has a good tutorial on how to setup using EIP but the customer is requiring drives that only use Profibus. I seem to be hitting a wall...o_O
I figure maybe someone has done something similar. Any, and I mean any help is appreciated!
Johnny
I think SBT should be able to use profibus since Phoenix has the profibus bus coupler.
My screenshots are attached.
The first one is the Prosoft AOI for comms.
The second is the main routine, the first rung being the SAFECONF AOI and the next rungs should be able to read/write the SBT I/O.
I am stuck on fail ctrl error 1013 cannot get IP nor can do firmware update need help pls urgent
170
Hi, I'm working with a Phoenix Contact FL NAT 2304-2GC-2SFP Ethernet switch, I already set the IP address and it has been working fine. I can...
1,288
Hi all, Historically i have used AB compactlogix exclusively working within the Logix/Studio5000 environment. I have decided to step out of my...
1,882
Hi all, first time poster and working on an existing PC TriSafe PLC for the first time for a project. I am wondering if anyone would know if...
1,115
(Rant)(CAD Models): Phoenix Contact Took the Time to say "FU!!" to their customers So obviously they have real CAD models of their parts because...
1,760
