If this is a new project, where you are starting from the ground floor than like Joltron says, you should be using symbolic addressing.
Using symbolic, after your create the DB, doesn't matter if its db1, or 2 or 3, or 4, or 100
You go in and define the variables you want to use in the block, and what type of variable they are. Once you have done that, you can then reference those variables through your HMI, or however else you want to manipulate them.
