Windows 10- RS Logix 20.04 Fatal Error everytime I open a project. Any thoughts ?
Cydog
Feb 2018
Maryland
313
Good Afternoon ,
I just purchased a Windows 10 Laptop. I installed RS Logix 5000 versions 16 , 17 and 20.04. Every time I open a Version 20.04 project , I get a Fatal Error . Rockwell told me to "repair" Version 20.04. I took notice that there is no "Repair" option in Add and Remove programs. Have any of you had this problem before ?
Thanks so much in advance .
I use 20.04 on 2 Win10 computers without problem. Are you running it as Administrator so it can create the use files?
The problem I have is when I try to install ver 20.05 it pops up that I have ver 23 of [something like motion design database] and need ver 32 and closes the installer. Can't find any download for it and trying to increment Studio5K versions up one by one doesn't update it until the next version halts.
Did you install them in order, or one after the other?
If you did the latter, the easiest option is to reinstall. The best option is to copy common files found in C:\Program Files (x86)\Rockwell Software\RSLogix 5000\Common\ from another computer to your fatality prone computer.
This only works is you have another computer with a higher version installed(You can use future common files too AFAIK).
Try running it in compatibility mode for Win7 or XP. I remember having a similar issue and one of the compatibility modes worked.....until Studio5k gets installed.
If you ever install Studio5k, uninstall your RSLogix 5k programs first. Install the latest Studio first and then any of the older versions (doesn't matter if studio or rslogix) and there should be no need for the compatibility mode after that.
Quick question that I can guarantee someone has the answer to... Is RSLogix 500 compatible with Windows 11?
24
4,211
Hi all, Has anyone found a quick way to patch in the functionality of the Windows help files in Windows 10 so it can be utilized in Logix 5000?
623
I'm getting ready to pull the trigger on my first purchase of OnLogic's Industrial Edge Computer to run Ignition Edge Panel. The PLC is a...
2,014
Hi guys, I am trying to install Logix 5000 ver 19.01 on windows 10. Are there any tips for the installation? TIA
6,533
V19 does not run on my Windows 10 laptop, I tried everything - run as administrator - compatibility Vista, 7, XP - reinstall .net framework Has...
5,279
