1769-l32e Slow to achieve comms with Panelview 1000 plus
Bly52
Oct 2017
Northants
Hi All.
Im currently working on a project which entails copying a project from Plc and Hmi to a like for like system. I have managed to put the original programs on both, using Logix 5000 and Rs Factorytalk view studio. I have setup communication path in Hmi . The Hmi all operates ok but takes about 6 mins to initially achieve communication and load flags from plc. I think the issue may be Plc end as when i put newly programmed hmi in original machine it operates fine.
All Comms are done on Ethernet direct no switch. Any idea where i could be going wrong.
TIA
BLY
Welcome to the PLCTalk forum community !
Why ? Virtually all control systems that use Ethernet also need a port to allow access via an engineering workstation or enterprise network router.
Check the cable very carefully, and check the network status and link LEDs on both the controller and the PanelView Plus.
Another diagnostic method would be to make the first screen on the PV+ a FactoryTalk Diagnostic object, and see what the error messages are.
One of the things the modern PV+ does that the older ones didn't is that it checks every Tag in the HMI project to be sure it's available from the controller at startup. If you don't have a good connection (and yours sounds like there's a badly damaged port or cable), the PV+ can sit for quite a while trying to read all the tags, before it actually gets around to putting the HMI into operation.
Problem solved
Thanks for the response.
as it turns out there was a damaged cable between Plc and Hmi.
I have no idea why no switch installed as the system was inherited but maybe once all is running i will look at adding a switch.
Thank you for the assistance.
Bly52
I just found two old 1769-L32E controllers in the plant that I cannot go online with using my version of Studio 5000 (30.14). I've reached out to...
2,026
Has anyone experienced the following issue on RSLogix5000 (currently on V16) I have a PLC program that has been running on a site for a number...
1,620
Hello; We have an Allen Bradley compact logic processor at an auto glue kitchen of corrugator machine which connected with AB HMI. Normally to...
2,444
Hello all, I have a small issue that I'm sure is something I overlooked but I'm stumped so I'm hitting the old Interweb to ask for help. On my...
3,976
Using Rslogix 5000 Data Access manual as a reference I keep getting 'Service Not Supported' response when using symbol instance addressing to...
1,573
