Siemens S7-1200
Simon Webber
May 2007
Cape Town
I have just received the Simatic S7-1200 starter kit & I am slowly but surely finding my way around the TIA portal. I've successfully set up the Profinet comms, created a simple program using timers, counters & a comparator. What I have found is that everytime I need to edit something in the FC, I need to take the CPU-1212C out of 'Run' mode, download the program again & go back into 'Run' mode.
The question is: With the S7-1200 series is there a way of doing program changes/edits in the 'Run' mode as it would be very inconvenient in real life shutting down a machine just to make a program change.
Not yet- but its coming
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
296
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
156
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
200
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
337
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
3,110
