Finding the license number in Step 7 V5.1
Mar 2010
Benalla
Looking for a little guidance in regard to digging out an installed license number.
I have a process line which has Siemens Step 7 Version 5.1 service pack 1 installed at the Scada console. I need to record the license number associated with this install to kick start a new service agreement with our local reps (support, service packs, etc), and I can't find the license number or where it is recorded in the software. Due to the age of the Installed Step 7, the hard copy and soft copy of the license is gone and my only hope of recording the number is if Step 7 Version 5.1 has some sort of ancient license manager software or batch file/executable i can't find in the Step 7 directory.
I am used to using the license manager that is included in versions 5.3 and later of Step 7, which clearly states the license number used for the installed product.
Any help on this would be greatly appreciated
I'm not familiar with older Step7 packages, but you could check your C:\AX NF ZZ folder. (It is hidden by default, change folder options to see it in explorer)
There should be a program called Automation License Manager in the computer. In the start menus simatic folder or directly in path ..\Siemens\Automation License Manager\almapp\almappx.exe. At least when using automation license manager 4.0.
There you can see different license keys installed on different hard drives and atleast in 4.0 the number of the license.
Thankyou for the replies :geek:
Unfortunatly the version of step 7 that is installed is 5.1, and in saying that, there is no obvious license manager under any of the sub-directories. I was hoping that under C:\Siemens\step7\S7Bin there would be an executable or batch file that would either display or prompt me to update my license number for my install of step 7, but seeing as i have no backup or support, double-clicking on the random executables and having something fail is not a desirable solution.
Again thankyou for the replies.
Look for "AuthorsW" inside your siemens installation folder or start menu - the Icon is a Red floppy disc.
On my computer its located in C:\SIEMENS\AuthorsW
make sure you canview hidden files and folders.Underthe above mentioned directory, look for *.ekb files.
These are the actual keys installed for authorization of your software.
Thank you to all who read and replied to my post :geek:
I have found that both solutions posted after my last post have pointed me to exactly where i needed. i assumed that AuthorsW was something to do with Authors of program files, not being an Authorisation program.
Again thank you very much all, for solving my issue :site:
Hi all, I'm in the process of upgrading a PanelView1200 HMI program to be developed in FactroyTalk View Studio. The filetype for PanelView 1200...
304
Hey all, pretty new to PLC and got a question regarding finding the MSB or the last non-zero bit in a SINT array in studio5000... I am reading...
844
Having an issue connecting to my Micro820 PLC. I don't have an IP Explorer and I know its MAC Address is 5C:88:16:D8:E6:65. I'm connected to the...
943
I have reached a dead end trying to find an EDS file. Manufacturer says to contact third party tech support. Clueless. RSLINX can see it, just...
1,817
Hello, I have an array of 300 of UDT. In each UDT is an array of 3 DINT and another array of 3 REAL. I have 10 controllers that pull data from...
1,178
