Wonderware Intouch + Delta PLC
valiantt
Oct 2012
Philippines
I am trying to integrate a Delta PLC (DVP-12SA2) with wonderware intouch to be used for a worm driven position control.
The program is almost finish but I am having problems with Modbus. (I am using the 'Modicon Modbus', included on the wonderware factory suite.)
I have also tried making a test program to try out all I/O tags with the PLC and it seems I can only get I/O discrete tags to work. Maybe it is improper addressing on my part? I am actually new to this I/O server.
I used these manuals I have found on google as reference:
www.google.com/search?q=modbus+delta+plc+intouch
I used the "How to use InTouch with DVP28SV11R/T + DVPEN01-SL" [pdf] and "DELTA PLC modbus protocol" [doc]" results. I mainly used the pdf and followed the modbus configs and intouch access name config. EDIT: I used 'MODBUS' instead of 'MBENET' on intouch access names.
on a sidenote, I am using rs-232, not r-485 to connect the plc to the computer.
also, can anyone help me with declaring floating point variables on Delta? I am also new to programming delta PLCs. I have been trying to find it out but to no avail. Examples will be really helpful.:)
I am using WPLSoft 2.30 to program the PLC
If there are anymore details you want to know about my problem, feel free to ask. :D
Anyone knows how to communicate Delta DVP-20SX PLC to Wonderware Intouch using ethernet (MBENET)/modbus ethernet? Using this I/O server MBENET, i...
2,398
195
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
192
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
477
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
221
