DELTA DVP-20SX PLC to Wonderware Intouch
heatse
May 2013
Manila
Anyone knows how to communicate Delta DVP-20SX PLC to Wonderware Intouch using ethernet (MBENET)/modbus ethernet? Using this I/O server MBENET, i am able to link the discrete i/o such as X (digital inputs), Y(digital output) & M (internal i/o). However, i cannot do it for Data Memory (holding registers). Please help me. Thanks
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
40
Hey guys, I've a requirement that a two different PLC program should work in same system depending upon user input. Consider Program A is used...
1,909
Hello, I'm facing a problem in communication between my delta TP70P-32TP1R HMI and DVP20EX2 PLC. I tried multiple ways in order to set the...
1,334
Hi all! I need help help with my delta module. Model : DVP-06XA-S Firmwire : 4.08 When i was setting my Rs485 parameter i...
908
Hello, someone know how to configure this PLC (DELTA DVP-14SS2) In the COM2 modbus RTU 485 baud rate 9600 8E1 slave mode (Not the plc Link)...
1,470
