Delta DVP-06XA module reset
Derwood
Aug 2021
Quebec
Hi all!
I need help help with my delta module.
Model : DVP-06XA-S
Firmwire : 4.08
When i was setting my Rs485 parameter i wrote a bad request and now i'm stuck cause i'm unable to communicate with it by Rs485 anymore.
The module is stuck with an RS485 station address of 0 (Unable to change that setting by direct connection with the plc or by Rs485)
I also manage somehow to change the RS485 communication. the Data i receive by serial connection in the register tell me i'm set in Hex at 8002 wiich would mean the communication protocol is RTU 8 E 1 at 9600bps.
i tried some software to auto-detect the communication protocol but they all failed. Also tried to reset to factory setting by serial connection, but no change occur on the communication and address setting.
Does anyone know how i could do a Factory reset of the module?
Thanks for your help!
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
40
Hey guys, I've a requirement that a two different PLC program should work in same system depending upon user input. Consider Program A is used...
1,911
Hello, I'm facing a problem in communication between my delta TP70P-32TP1R HMI and DVP20EX2 PLC. I tried multiple ways in order to set the...
1,339
Hello, someone know how to configure this PLC (DELTA DVP-14SS2) In the COM2 modbus RTU 485 baud rate 9600 8E1 slave mode (Not the plc Link)...
1,471
I have DVP12SE and I can configure its ip properly. I can ping and remote program. What I don't understand is how to actually USE modbus tcp in...
1,594
